报错详细内容:
fatal: [master]: FAILED! => {
"changed": false
MSG:
Command failed rc=1, out=, err=Could not get property: 连接超时
NO MORE HOSTS LEFT *********************************************************************************************************************
PLAY RECAP *****************************************************************************************************************************
localhost : ok=1 changed=0 unreachable=0 failed=0
master : ok=10 changed=0 unreachable=0 failed=1
node1 : ok=11 changed=0 unreachable=0 failed=0
node2 : ok=11 changed=0 unreachable=0 failed=0
Tuesday 07 April 2020 03:49:48 -0400 (0:00:25.412) 0:00:35.044 *********
bootstrap-os : Assign inventory name to unconfigured hostnames (non-CoreOS, Suse and ClearLinux) ------------------------------- 25.41s
bootstrap-os : Gather host facts to get ansible_os_family ----------------------------------------------------------------------- 5.52s
download : download | Sync files / images from ansible host to nodes ------------------------------------------------------------ 0.54s
download : download | Download files / images ----------------------------------------------------------------------------------- 0.54s
bootstrap-os : Install libselinux python package -------------------------------------------------------------------------------- 0.45s
bootstrap-os : Create remote_tmp for it is used by another module --------------------------------------------------------------- 0.28s
bootstrap-os : Check if this is an atomic host ---------------------------------------------------------------------------------- 0.23s
bootstrap-os : Disable fastestmirror plugin if requested ------------------------------------------------------------------------ 0.23s
bootstrap-os : Check presence of fastestmirror.conf ----------------------------------------------------------------------------- 0.19s
bootstrap-os : Fetch /etc/os-release -------------------------------------------------------------------------------------------- 0.12s
bootstrap-os : include_tasks ---------------------------------------------------------------------------------------------------- 0.10s
bootstrap-os : Store the fact if this is an atomic host ------------------------------------------------------------------------- 0.10s
kubespray-defaults : Configure defaults ----------------------------------------------------------------------------------------- 0.10s
Check ansible version >=2.7.8 --------------------------------------------------------------------------------------------------- 0.09s
download : prep_download | Create staging directory on remote node -------------------------------------------------------------- 0.07s
download : prep_download | Parse the outputs of the previous commands ----------------------------------------------------------- 0.06s
download : prep_download | Set a few facts -------------------------------------------------------------------------------------- 0.06s
bootstrap-os : Add proxy to /etc/yum.conf if http_proxy is defined -------------------------------------------------------------- 0.06s
bootstrap-os : include_tasks ---------------------------------------------------------------------------------------------------- 0.06s
failed!
please refer to https://kubesphere.io/docs/v2.1/zh-CN/faq/faq-install/
按文章配置了host.ini
common.yaml
防火墙已关
